Where to hard wire dash cam?
28K views 16 replies 13 participants last post by  GTyankee
#1 ·
Hey guys, now that the tint is done, I can install the dash cam. The only way I've done it before is to snake the cord from the headliner, down the pillar, behind the glove box, then plug into an empty plug. Not the best looking.
I'd like to hard wire the cam. My first choice, if available, is the upper console where the dome lights are. I only need power when the truck is on.
Ideas?
#2 ·
I thought of using the dome light, but they are powered full time. I wonder if you could use the garage door opener(s), as it only works with the ignition on? At least that's where I plan to go for power when I hook up my dash cam this spring/summer. Like you, I don't want excess wires run all over. Looks tacky...
I am still trying to think of a place to mount my ham radio, and it's antenna without looking gaudy.
Thoughts?
#5 ·
Hot damn! We have winner!
Repped
#4 ·
@Ramdandy - Thanx, I had forgotten all about the rear window switch!
#11 ·
I ran mine in through the front edge of the overhead console, across the headliner, down the A pillar and under the dash to the 12V power outlet wiring.
-K
#14 ·
X2 on the mirror tap. Power should be pink wire with yellow stripe. Ground right next to it. Two wire harnesses up there. Its the lower, bigger one on the passenger side.
Hope I got that right. Didn't do it that long ago. LOL. :4-dontknow:
#17 ·
This company seems to have hard wire cables for certain dash cams
They wire directly from the mirror to the camera
https://www.blendmount.com/filter.html
they suggest using a Blackview camera, because it is low profile i believe
https://www.blendmount.com/results-...ap.html?Make=DODGE&Year=2014&Model=RAM+TRUCK+1500&Category=Dash+Camera&Brand=Bl
this guy went a different route, he made his own setup
https://www.youtube.com/watch?v=Ez2JmZmKxR4
other installs
https://www.youtube.com/results?search_query=blendmount+dash+cam+install+dodge+ram+1500
