141 - 156 of 156 Posts
Discussion starter · #142 ·
Sorry to hear about your issue ,as there is no Lemon Law in canada,but if you check near the end of your owners manual you can chech out CAMVAP.I had a 03 Liberty, transmission slipping. I finally threatened the dealer I was going to CAMVAP and miracously, they agreed to replace my transmission. It's Canadas version of the lemon law. It's actually an arbitration panel that decides what to do with your truck. Just call them and check it out. Can't hurt. good luck
I've looked into it extensively, but I'm not sure if I want to go that route. It doesn't seem that they really have any provisions for a "problem vehicle" but more for whatever issue that you're having. Maybe I will call them and talk to them, it can't hurt then make my mind up from there.
This is something I did find interesting though in my research: "Chrysler comprises the largest share of arbitration cases with a very substantial 32% share. A review of the complaints reveals a higher number of problems per vehicle for Chrysler products than other brands, with multiple issues per vehicle occurring more frequently."
And: Chrysler was ordered to buy back its vehicles approximately 40% of the time (more than any other automaker)."
Discussion starter · #143 ·
Now the uconnect system has started randomly restarting songs on me or will skip to the next song in the middle of listening to music on my sd card or iPod. Haven't seen if it does it on the radio or not.
This things possessed or something lol.
You know, across multiple cars / trucks i've had with uconnect, they all have the exact same single issue, which is my only actual issue. When I have my iphone plugged in, and i want to go to listen to music, BLUETOOTH won't work while it's plugged in, neither will siri, then when I unplug it, bluetooth still sometimes won't work, if i plug it back in, and try to play, it plays from the phone speakers instead of the radio. It's extremely tiresome and annoying.
Is that only when its plugged into the data port or the charge only port as well
get rid of the iPhone works fine with my samsung
I agree, my Samsung works better than my wife's Iphone; Apple software is incompatible with a lot of things
I did figure out how to get her Durango to read her texts finally.
Discussion starter · #147 ·
Yeah I use an android phone and have no problems with that, I can have it plugged in charging and still use bluetooth.
Droid here and no problems. Just make sure you use the charging port.
FWIW, I had a 2010 Ram with the 5.7 that on occasion would make the lifter noise you have on startup. It's most likely because the oil filter anti drain back valve isn't seating properly and your losing the oil prime in your engine. When you start up you hear the hydraulic lifters clacking until the oil pressure is built up again and the lifters pump back up. Use a high quality filter like a Mobil 1 filter and see if it subsides.
As for everything else I know it's frustrating but there are much worse thing in life to deal with. My 2015 Power Wagon hasn't been perfect but I've owned enough new vehicles to know that none are ever perfect.
Discussion starter · #151 ·
Thanks for the heads up, I'll try a different filter at the next oil change. I'm not sure what the dealer used but I'm sure it's a Mopar filter thats on there now.
As far as everything else, I agree that things happen, things break, and vehicles are mass produced so theres bound to be issues here and there every now and then. BUT I think the issues with this truck are definitely excessive and the huge range of issues that its had so far (nothing thats gone wrong is related to anything else thats gone wrong, its just a ton of separate components) is unsettling. Then there's the fact that the car that I traded in had only 60,000km (37,500 miles) on it and had no issues whatsoever and never saw a service bay except for routine maintenance, so it's extra annoying that I'm at the dealer with my brand new truck every 2 weeks. It also doesn't help that I work graveyard shift so when I do have to take the truck in I'm losing a ton of sleep over it every time as well, not that that's Ram or the dealers fault, it's just extra inconvenient for me.
Discussion starter · #152 ·
Just wanted to update this incase anyone else has this issue. I soft reset the connect system, (hold the mute and tune buttons until it reboots itself) and haven't had any more issues with is skipping songs or radio stations. It's only been about 2 days but it has had no issues since.
Hello, I'm a Newbie to the forum, but was glad to hear that the Ticking on start up's are characteristic of the Hemi, I have 35k on mine and it doesn't happen all the time but when it does definitely will get my attention.
