Does anyone know what the equivalent fluid is to the Mopar t-case lube for trucks equipped with the Borg Warner 44-44 transfer case? I am wanting to change the oil in my difs and t-case but cant find that info.
I didn't say correct as in brand. What I'm saying is the correct 'type' of fluids to use is all in the owners manual if one cares to read it. As you say, they are good oils. By the time all the strangers offer their advice on what to use the job could have been done by now by just going to the dealership and buying from them. If we were all in agreement on which is best there'd be a clear winner but thats certainly not the case.Correct fluid doesn't just mean OEM. Pennzoil, Amsoil, Royal Purple, and Mobil are all good oils despite not being the "Mopar" oil
Think about it. Do you really think Amsoil or any other brand isn't out for your money? Do you not wonder why Amsoil doesn't say just use what the manufacturer says to use? If you think Dodge is trying to rip you off why did you buy one?![]()
Really, "MOPAR" doesn't stand for quality one minute. Its just a way for dodge to rip you off. The Owners manual is there to make sure they get your money.
I called Amsoil this morning and they pointed me to the data sheet and confirmed its use for the BW 44-44 T-Case. The data sheet has the Mopar part number listed in the specifications as approved for use. :smileup:That's interesting, somebody should call Amsoil about it and ask if it really is for the BW44-44. I would but I'm not in the US.
The BW 44-44 is used by Ford and Ram so its pretty popular and it makes sense there would (finally) be an aftermarket fluid for it. I was just going to buy the Mopar fluid from the dealer, but this is probably no more expensive and is likely better. I wouldn't pay someone to change the t-case fluid, its just too easy; easier than engine oil.
Hey, I just wanted to thank you for taking the time to offer this valuable input! It made such a difference in assisting me in the search for the answers to my questions.Why not just buy the correct fluids from the parts department and be done with it? The owners manual tells you what you need to buy.
There you go. Talking to Amsoil directly is the best thing to do. :smileup:I called Amsoil this morning and they pointed me to the data sheet and confirmed its use for the BW 44-44 T-Case. The data sheet has the Mopar part number listed in the specifications as approved for use. :smileup:
I got Redline for my upcoming diff fluid change. I ordered 75W140 for the rear, 75W85 for the front per the manual (only Mopar and Redline make 75W85), but I ordered a bottle of their friction modifier too. It meets the specs of the Mopar FM and IDK if I really need it, but I want it just in case the oil doesn't have quite enough blended in. I don't think it'll really be a problem though since IIRC its a pretty standard proportion.Well just have a look at Amsoils website. in the notes it says to add Mopar oil additive for the rear diff :smileup:
or Just get RedLine oil and you dont have to worry about the additive https://www.amazon.ca/dp/B0045FE6OW...ef=wl_it_dp_o_pC_S_ttl?_encoding=UTF8&colid=2272ET0CNJD0J&coliid=I3IQECXNGTDS68.
The 44-45 uses ATF+4I purchased 2 quarts of Mopar 68089195AA Transfer Case Lubricant for Borg Warner 44-44 Transfer Case on Ebay for $36.00 with free shipping. Also works for the Borg Warner 44-45 Transfer case. Shop around. The Stealership is the last place I would go. Not sure what the Amsoil lube costs, but the Mopar stuff is synthetic as well. -Glen
You said get it from the parts department; AFAIK parts departments only sell Mopar fluids. Sorry for any confusion :wavey:I didn't say correct as in brand. What I'm saying is the correct 'type' of fluids to use is all in the owners manual if one cares to read it. As you say, they are good oils. By the time all the strangers offer their advice on what to use the job could have been done by now by just going to the dealership and buying from them. If we were all in agreement on which is best there'd be a clear winner but thats certainly not the case.
No worries.You said get it from the parts department; AFAIK parts departments only sell Mopar fluids. Sorry for any confusion :wavey:
I don't know about that. I had the dealer run my Vin# and I have a BW44-45 transfer case. Also Amsoil's website lists the same fluid for the BW44-44 & BW44-45 transfer cases with the Mopar equivalent being 68089195AA. http://www.amsoil.com/lookup/auto-and-light-truck/2012/ram/1500-pickup/4915431/us-volume/ . -GlenI got Redline for my upcoming diff fluid change. I ordered 75W140 for the rear, 75W85 for the front per the manual (only Mopar and Redline make 75W85), but I ordered a bottle of their friction modifier too. It meets the specs of the Mopar FM and IDK if I really need it, but I want it just in case the oil doesn't have quite enough blended in. I don't think it'll really be a problem though since IIRC its a pretty standard proportion.
I don't since the 44-44 in my truck doesn't use ATF+4, but since the manual states under transfer case:See this from MoparOverstock.com: http://www.moparpartsoverstock.com/showAssembly.aspx?ukey_assembly=897942&ukey_product=10709874 . Do you want to run ATF+4? -Glen
I am at about 52,000 and will be changing my axles and t case soon. This will be the first time I've ever changed diff or t case fluid on a vehicle.Thunder is this the first time changing the transfer case and axle fluids at around 60k? You pretty much gave me the same idea to do mine myself next summer since I can get all the fluids for around $130 or less.
Whats your plan for the trans now?
Laramies come with the 44-44 with the auto 4wd.Does your Laramie have the "auto" feature?
pulling the covers?I am at about 52,000 and will be changing my axles and t case soon. This will be the first time I've ever changed diff or t case fluid on a vehicle.
pulling the covers?
What are you going with for the T-case fluid?
It threw me off when he said he had the 44-45 on his Laramie.
Thunderhorse, Thanks for the clarification. I did crawl under my truck and could not locate a tag on the transfer case, that's why I had a dealership run my Vin. #. I thought I had the BW 44-44 transfer case. I was surprised that I was told otherwise. Yesterday, I crawled under my truck, and finally found a barely readable sticker that confirmed I do have the BW 44-44 transfer case, and not the BW 44-45 part time transfer case. I have read my owner's manual and it states that ATF+4 is recommended for all transfer cases except the BW 44-44 transfer case. On the plus side, I bought the correct fluid for my transfer case, and what I've learned is the Dodge dealers here on Long Island are a bunch of morons. So be skeptical of the dealer parts departments, and don't believe what you read on internet dealer websites. Thanks very much. Regards, GlenI am at about 52,000 and will be changing my axles and t case soon. This will be the first time I've ever changed diff or t case fluid on a vehicle.
